Re: Fixing gas tank
Posted by deano4863 on November 02, 2009 at 18:24:15 from (76.30.75.21):
In Reply to: Fixing gas tank posted by BruceS. on November 02, 2009 at 14:51:56:
I had a similar issue with a H tank. Bad threads and leaking. We ended up cutting a 4" square piece out. We took the replacement 4" new piece of metal and welded in a 3/8" pipe coupling in the center. I had a professional welder do the work and by the time we primered and painted it it worked perfect and looked good.
Be safe! The original cut was made with the tank inverted and almost full of water.
