Re: SA electrical problems
Posted by John G. Hasler on November 02, 2009 at 19:03:39 from (174.124.36.161):
In Reply to: Re: SA electrical problems posted by Janicholson on November 02, 2009 at 16:15:26:
> With respect, the resistor between the coil and
> distributor is very different than having it
> before the coil.
No it isn"t.
As long as the coil and resistor are in series and nothing is in parallel with either the same current flows through both. Order doesn"t matter.
