Re: farmall 350 hyd
Posted by bkpigs on November 03, 2009 at 05:32:45 from (12.50.51.2):
In Reply to: farmall 350 hyd posted by robison on November 02, 2009 at 21:15:17:
Can you get a cylinder to move when you change the lever position? If it does that will take a passage bloackage out of the equation. The next thing would have to be that your regulator is not letting the fluid to bypass the valves. Take the Safety-regulator block off again and make sure nothing is impeeding the movement of the regulator valve.
