Re: What's the COLD valve lash setting for a C-135?
Posted by rustred on November 03, 2009 at 05:46:54 from (142.179.188.160):
In Reply to: What's the COLD valve lash setting for a C-135? posted by tesmith66 on November 03, 2009 at 04:40:15:
give it a couple more thou. if setting them cold. as the metal heats up it will decrease the clearance.you could take it out and work it , get it hot then pull the cover and check the clearance to the specs.
