Re: farmall 350 hyd
Posted by dhermesc on November 03, 2009 at 08:46:11 from (24.248.193.103):
In Reply to: farmall 350 hyd posted by robison on November 02, 2009 at 21:15:17:
Did you check the valves settings that switch between 2 way and 1 way cylinders? Its in front of the steering wheel, two are under the cowl and one is exposed via a hole in the sheetmetal (if you have three outlets). If these valves are in the "half way" position they will create back pressure and pull down the engine.
I have one (thankfully the exposed one) that turns on its own and I am constantly resetting it to the lock position.
