Posted by dpski on November 03, 2009 at 09:26:12 from (128.221.197.56):
I"ve been doing a ton a research here on all the threads about the Touchcontrol Hyd pumps leaking into the crankcase, which mine is. Mine has an O-Ring type seal, and the shaft is grooved so looks like speedi-sleeve time. Question is do you leave the flange at the base of the speedi-sleeve attached to the sleeve?
Or did you remove it?
Is there enough clearance inside the pump, between the shaft base where it meets the gear such that the flange will not interfere with anything inside the pump?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
