F-20 Rear Main
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Hotwater on April 24, 2000 at 02:27:56 from (208.6.8.57):
When changing My oil I noticed some pieces of metal in the plug. After Ipulled the oil pan I noticed the main bearing was missing part of the bearing retainer and it was in the bottem of the oil pan. Is this A common thing to happen? Would it hurt any thing to run it through the summer and put a new bearing in in the fall? The tractor is used for light duty only and gets 20 to 40 hours on a year.
Post A Followup
: Re: F-20 Rear Main
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
