Rectangular cover with 4 bolts, may have a seal wire one the front outside bolt. Right under the cover is a threaded screw with a nut and a tab bent against the nut. Straighten the tab, loosen the nut, back the screw out 1 1/2 turns for 30HP.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
