Re: SA electrical problems, part 2
Posted by ScottyHOMEy on November 03, 2009 at 18:27:56 from (70.105.237.111):
In Reply to: SA electrical problems, part 2 posted by Mark on November 03, 2009 at 15:46:46:
I stepped outside fro some fresh air and a cigarette and got thinkin' that my ealier response wasn't gonna cover it. About that time, my neighbor hollered over, and I went to go catch up and discus the elections and other neighborhood happenin's and lost all track of time.
But I see the others jumped in with some good ideas.
A thought I had just before Neighbor Dave hollered to me . . . How are you checking for spark at the plugs. Are you doing a static timing (motor stopped at TDC and trying to dial the distributor in until you get a spark) or are you cranking the motor over and never getting a spark? If the static timing, how far have your turned the distibutor. Wondering if you might simply have it 180* out -- not hard to do, happens a lot. (If far enough off, it could just as easily be the indexing that John T and a couple others mentioned -- 1080* is just the extreme case of that)
If looking for a spark while cranking, have you checked a plug wire grounded to chassis (just like you did with the coil wire)? If so does any wire spark at ANY point? If not, with everything else you've replaced (and I DO mean everything), that really leaves the plug wires or their connectors as prime suspects.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
