Posted by John T on November 03, 2009 at 19:18:47 from (66.244.97.31):
In Reply to: John T Question???? posted by JohnDeere2Cylinder on November 03, 2009 at 18:05:02:
Youre welcome, thanks for the kind words, Im glad to help when I can. I've learned a great deal here from Bob (the ex mayor) and Bob M and Jim (janicholson) and other gentlemen, and they may have even learned from me a time or two...
Im not sure just what happened, but can say if you hook a charger backwards to a battery (charger + to battery -) she will indeed pop n spark n raise the dickens..... It dont matter which battery post (+ or -) happens to be bonded to some huge hunk of iron (the tractor frame) they still connect to the charger + to + and - to - And a genny can work fine at EITHER Pos or Neg ground provided its properly polarized
I guess what Im saying is I cant be sure if the battery wasnt okay and you hooked the charger wrong or if something else was actually the case?
Nowwwwww if a battery is like dead it might be connected to a charger wrong and NOT spark so much as described above and if was left connected that way and a person wanted to start all over and wasnt sure what may have happened to that battery before..... I think I would place a small load on the battery like a headlight n let it burn out to completely discharge the battery and let it set a while and then hook it correctly to a charger and put it at on a slow charge rate n just let her cook a while n see how she recovers.
Thats my best shot not being there and not really knowing what may have happened.
Whatever you do Id re polarize the genny before you crank her up
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
