TD-9 Rear Main Seal
Posted by Dan Woodall on November 03, 2009 at 20:16:56 from (69.44.241.164):
I have developed a major oil leak on my TD-9 at the rear main. The past summer I attempted to replace it by going through the openening in the clutch housing. I quickly found out I could not get the flywheel out and reassembled it leaving it for a later date.
So, is the best way to replace the seal by moving the engine foward, or is it possible to get to it througn the clutch housing? If so, how? Thanks in advance, Dan.
