Re: Cub oil pump shaft loose
Posted by Jim Becker on November 03, 2009 at 21:59:03 from (71.252.159.128):
In Reply to: Cub oil pump shaft loose posted by PaceF20s on November 03, 2009 at 17:27:29:
Probably depends on just how loose it is. Loctite has some products designed for assembling things that are supposed to be a press fit. Check the Loctite product specs. If there is one with specs that match your situation, use it. If it is too loose for Loctite, use JB Weld.
