Re: 2 way hydraulics on super m
Posted by mkirsch on November 04, 2009 at 05:07:17 from (64.80.108.57):
In Reply to: 2 way hydraulics on super m posted by oldiron29 on November 03, 2009 at 11:31:15:
jdetig1 said: (quoted from post at 19:04:09 11/03/09) so your saying i need to get another valve to run the 2 way cylinder and just leave the original lever pulled back at all times?
Also will this power both ways on the cylinder or just one way and let the weight of the implement push the cylinder rod back in?
Yes, you need a separate two-way valve to run a two-way cylinder, and leave the M's lever pulled back at all times.
This will power the cylinder both ways.
What you are doing is building a two-way system on top of the M's one-way system. More modern tractors do basically the same thing, except it's all done under the covers, without the one-way valve.
