Posted by Janicholson on November 04, 2009 at 06:20:48 from (199.17.6.222):
In Reply to: Wiring size question posted by Mike CA on November 03, 2009 at 20:49:53:
The difference between the Mag wiring, and the coil wiring is only the method of using the wire going to the mag. All other wires should be identical to the coil wiring. Use the mag wire as an ignition wire from the existing ignition hot when in the run position terminal, to the coil (or resistor if you have that type of coil). Then when putting on the mag, you will change this wire from hot when on to a "mag kill switch" which is grounded when pushed in, and off when pulled out. It will then be attached to the mag Kill terminal. Do it in this order to prevent putting voltage to the mag, they do not like battery voltage at all. JimN The 6v wires are just fine, and the job would be almost completely done if this method were used. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
