Re: Stuck engines
Posted by bc on November 04, 2009 at 15:56:14 from (69.148.145.104):
In Reply to: Stuck engines posted by Bernie Steffen on November 04, 2009 at 13:32:23:
Good question Bernie. I suspect that if a piston was stuck to a cylinder because of rust, then one of the phosphoric acid solutions would be appropriate. Found in the paint department at home cheapot. Behr and someone else makes some. Usually call it concrete etcher.
For that matter, regular ol HCL/Muratic acid cuts rust quickly and is cheaper than phosphoric.
Ought to work for the water jacket passages as well.
There's no rubber or other parts between the heads and oil pan that can be eaten up that I can think of except for the pan gasket and maybe water pump seals but the water pump shouldn't see any if you used a squirt can to squirt acid into the spark plug holes.
Don't quote me on this, I'm just guessing.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
