Posted by gbs on November 04, 2009 at 18:27:46 from (209.177.239.222):
In Reply to: Stuck engines posted by Bernie Steffen on November 04, 2009 at 13:32:23:
you stated head and crank were removed, if this be the case and if cylinder wall isn't too rusty below piston ,wet it down with penetrating oil of so kind ,take a block of hard wood place on top of piston hit with hammer, drive piston down below were top ring was sitting , clean up cylinder with sand paper,emery etc.,top of cylinder may need to be ridge reamed also,use a brass drift pin set against wrist pin boss in piston or connecting rod below wrist pin slowly drive it out, if it gets tight or excessive rust is below piston when first trying to break loose drive it a little each direction until it frees up, be presistant you will get them out
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
