Re: SA electrical problems partially solved
Posted by gbs on November 04, 2009 at 18:55:21 from (209.177.239.222):
In Reply to: SA electrical problems partially solved posted by Mark on November 04, 2009 at 13:17:14:
had a auto mechanic's teacher in high school that was as good a tractor mechanic as they come,he converted a many a tractor to 12 volts,he warned us about disconnecting the battery while engine was running to see if alt. was charging enuogh to keep engine running,he said that if circuit was disconnected that the regulator sometimes wouldn't control the voltage and it would spike burning up electrical parts,well hard headed me kept doing it any from time to time until i blistered the alt. and coil on my sa ,had to replace them instead of cultivating that morning live and learn.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
