Re: sticky neutral
Posted by TractormanNC on November 05, 2009 at 06:09:30 from (209.42.180.90):
In Reply to: sticky neutral posted by Lifeline on November 04, 2009 at 18:48:21:
The pivot for the TA handle has no provision for greasing. Some of your favorite unstickum juice followed by liberal oiling should fix this.
On the gear shift, there is a grease fitting inside the battery box near the top. Maybe some unstickum juice before greasing.
Also, make sure there is no excessive slop in the linkage and that it is adjusted properly.
While you are at it, adjust the engine clutch and the TA linkage BY THE BOOK. Close doesn't count here.
