Re: Enlighten me, please!
Posted by Wardner on November 05, 2009 at 07:56:52 from (4.154.240.41):
In Reply to: Re: Enlighten me, please! posted by rustyfarmall on November 05, 2009 at 06:41:36:
Yeah, the detent spring makes sense but why so
big?
The width of the raised part of the casting (left to right as installed) would
seem to indicate two small gears on two separate
shafts. That would be necessary if one of the
gears was meshed to the 4th/5th slider. Otherwise
the tractor would have four gears in reverse and only 5th and reverse going forward.
FWIW, the picture below is how the Elwood transfer
case extracted power from the 4th/5th slider on
the large framed tractor. On the H being discussed it would be
reversed. Power would come off the BP gear or constant mesh gear with
one gear and it would be sent over to the other side of the
tractor. At that point, a wide sliding gear would
mesh with the 4th/5th gear on the mainshaft.
Which attachment gear slides is unknown but the
other gear would be in constant mesh and probably
noisy.
I have been thinking about doing something similar
to a W-9. But the method would be totally
different. I was thinking about running two
countershafts in the transmission. I think Oliver
did that on their industrials and maybe on the
rowcrops as well.
third party image
<a href="http://s140.photobucket.com/albums/r16/Wardner/?action=view&current=creeper102.jpg" target="_blank"><img src="http://i140.photobucket.com/albums/r16/Wardner/creeper102.jpg" border="0" alt="Photobucket"></a>
This post was edited by Wardner at 12:20:04 11/05/09 2 times.
