Re: Hex head vs. square head? And Grade 5 vs 8?
Posted by bc on November 05, 2009 at 09:02:40 from (69.148.145.104):
In Reply to: Hex head vs. square head? And Grade 5 vs 8? posted by Mike CA on November 04, 2009 at 21:00:55:
If they were bent, I'd suspect grade 2. The higher the grade the more likely they break and not bend.
So grade 5 would be plenty or go back with 2.
Hex or square depends upon if you are using a wrench or socket. Tight squares are ok if you can get a wrench on them but anything recessed just about takes a socket.
You also need to look at the recommended torque before making your decision.
