Posted by rustyfarmall on November 05, 2009 at 09:23:04 from (209.152.78.140):
In Reply to: engine oil sludge posted by Andrew Z on November 05, 2009 at 09:15:51:
I will suggest removing the oil pan, clean it thoroughly, and re-install. A new gasket for the oil pan will cost you around $10 or less. Refill with fresh motor oil, but you might want to replace 1 quart of oil with 1 quart of "Rislone". Run and use the tractor for awhile and then change the oil and filter again. You might need to do several oil and filter changes, but eventually the sludge will be cleaned out. I think some of the guys are now using "sea foam" instead of the "Rislone"
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
