Posted by Bob M on November 05, 2009 at 09:46:29 from (151.190.254.108):
In Reply to: engine oil sludge posted by chickenfarmer on November 05, 2009 at 09:15:51:
The lion's share of the sludge will be lying on the bottom of the pan. Drop the pan to clean it out. Also check and clean the oil pump pickup screen while the pan's off.
There will be a lesser amount of sludge under the valve cover and perhaps behind the tappet cover (magneto side of the block). You should remove both covers and clean out anything you find there too.
When you are finished give the head good final flush with clean solvent (kero, diesel, etc) then blow with compressed air to make sure all oil drain passages are clear.
Button the engine back up (use new gaskets!) and it should be good to go.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
