T.S. Eliot said: (quoted from post at 11:47:39 11/03/09) I'm hoping I can get by without adding it, but I do eat my Wheaties on a regular basis. It really doesn't steer much harder than when it had the factory wide front and triple ribs.
Yeah, but pick up a big bale with the grapple hooks and see how it steers... A nice seat, PS and some squared fenders and it could be a really cool modern tractor. I think a Char-Lynn unit would fit under the hood. I would imagine to get the presssure to lift a bale, you have an auxillary pump and valves... tap off that with a priority flow valve and you would be all set.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
