Re: C113 head on 123 block?????
Posted by tractorsam on November 05, 2009 at 18:29:32 from (99.192.79.228):
In Reply to: C113 head on 123 block????? posted by ctallen2002 on November 05, 2009 at 15:54:27:
The other thing to watch out for when you reasseble it is that you install the correct head gasket. If your tractor has a water pump (and it should) then you will need the gasket with the smaller holes for the coolant passages. Sam
