Re: Should I, or shouldn't I? Removal of a pin.
Posted by Wardner on November 05, 2009 at 21:20:36 from (4.154.241.157):
In Reply to: Re: Should I, or shouldn't I? Removal of a pin. posted by Mike CA on November 05, 2009 at 20:29:43:
You didn't indicate where the post was tweaked
(only how it was tweaked) so it is not possible to
tell you exactly how to untweak it.
If the distortion is at the base flange, a come-a-
long will do. If the damage is somewhere in the
tube length, remove the column, and press or bang
it out with a hammer and block of wood. Might want
to cut a notch in the wood block to spread the
impacts. Don't mess with the rivet. Motorcycle
fork tube are spun in a lathe to check runout.
But you haven't a lathe so don't worry about it.
A straightedge will get you close enough.
You should straighten it. You might be surprised
how a slight misalignment can affect the amount of
effort required to turn the steering wheel. The
misalignment causes the steering shaft and bearing
to bind.
