Re: Magneto or Distributor
Posted by ScottyHOMEy on November 06, 2009 at 03:25:07 from (70.105.255.111):
In Reply to: Magneto or Distributor posted by noobie on November 05, 2009 at 20:23:38:
third party image
Assuming you're talking about a letter series tractor or a Cub, so here's a smaller picture of an H4 magneto, which was the standard mag for the letter series. The J4 on the isn't much different.
Yours may be painted.
A battery ignition will have an external coil like Mike shows and old describes, with the one large wire from the coil to the center of the distributor cap. On the H/J4 mags the coil is internal, and that wire runs to the cap from the end of the other, more rectangular, cap on top of the mag.
