Re: S/C Farmall starter
Posted by rustyfarmall on November 06, 2009 at 07:40:54 from (209.152.78.140):
In Reply to: S/C Farmall starter posted by Mike CA on November 06, 2009 at 07:16:31:
Replace the starter drive on the Super C. The teeth on that drive are worn and will "catch" in the teeth of the ring gear on the flywheel. It is a common ailment on these old tractors. To fix it 100% right, you should probably replace the flywheel ring gear also, but I think just the starter drive will probably get you out of the woods.
