Re: S/C Farmall starter
Posted by Bob M on November 06, 2009 at 08:31:29 from (151.190.254.108):
In Reply to: S/C Farmall starter posted by S/C BOB on November 06, 2009 at 07:16:31:
That's a sure sign the starter bendix is jamming in the ring gear.
Sometimes installing a new bendix solves the problem. But if the ring gear is badly worn a new bendix it can actually make the jamming problem WORSE. Only fix then is to replace the ring gear.
(Note: You can also flip the ring gear around so unworn gear teeth are facing the starter. But you still gotta split the tractor to do it. Better to spend $40 for a NEW gear when you have it apart!)
