The new style starter drive refered to is not actually a clutch type. It still is inertia engaged and does not have a overunning cluth. It does have a reselient type of shock absorbing mechanism and works very well usually. Over the years I have had two of them that did not, they were very sticky and would not engage on the 6 volt system, one of them was mine just last winter. No amount of tweaking it would get it to be reliable every time, however, they gave me another new one . Should have, at $75 at CaseIH. One more thing, to look at them you would say, this isn't going to work and also, you can leave out the two spacer washers that were used with origninal bendix style. Must of course keep the small ID one to control end play of armature. Far as undercutting an armature, if it was I do, if it wasn't I do not. Auto lite as used on Chrysler products way back in the 40's did not undercut, Delco quit doing it somewhere in the 60's or so. You don't smear the copper in between the bars nearly as bad when it is not undercut. My op.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
