Re: Farmall wobble problem update
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 24, 2000 at 11:42:15 from (206.246.187.2):
In Reply to: Farmall wobble problem update posted by Ed E on April 24, 2000 at 11:26:21:
As long as that steering shaft is connected tight at the U joint, it won't walk out of the worm gear. When you get the bearing replaced make sure the cap is tight and you will be fine. Was the castle nut and cotter pin on the end of the shaft after you removed the cap?
Post A Followup
: Re: Re: Farmall wobble problem update
