Re: '49 Super A Wheels
Posted by ScottyHOMEy on November 07, 2009 at 05:53:32 from (71.241.217.23):
In Reply to: '49 Super A Wheels posted by Dalex on November 06, 2009 at 21:11:58:
Athol's spot on about the wheels. That was a very common arrangement.
As far as the water pump, it was only on the SuperA-1 that they used the 123 motor (basically the same as the SuperC) with the water pump as standard. On the 113 used in the Super A, it was a thermosiphon system and no thermostat.
I'm pretty sure there's room in the front casting of an A to bolt a water pump on -- it bolts up the same as the plain cast inlet. It requires a longer belt, and a different arm for adjusting the tension on the generator. Teh upper outlet neck won't have any provision for holding a thermostat in place for use with a pump, so it takes some hunting and fiddling to find inserts that will fit to accomplish that.
The old girls ran fine for years without the pumps. The fans on them are high volume for what the motor is and they'll run all day working hard without overheating. If your ever hear one working from a distance, you'll be hearing the fan, not the exhaust.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
