Re: OT TV Antenna
Posted by jdemaris on November 07, 2009 at 07:18:01 from (67.142.130.33):
In Reply to: OT TV Antenna posted by John T on November 07, 2009 at 07:02:09:
Yes, an antenna works the same, analog or digital signal. But, it must have low-band VHF for VHF up to channels 6. Must have high-band VHF for channels 7 to 13. Must have UHF for channels 14 to 51.
The problem had been this. In many areas, channels that had been on VHF, changed over to UHF to go digital. Also, many local TV stations began to borrow transmitter towers further away.
So, in your case, you need to determine #1 if your antenna can receive UHF bands, and #2 what is now available in your area, and on what band.
Simple check is just go to TVFool.com and punch in your address or GPS coordinates. It will give you a free report of exactly what is in your area, and at what signal strength.
Anything with a positive noise-margin number will be good without much trouble. If you have a good antenna and preamp (LNA), you can get digital and analog from up to 140 miles away with a negative 30 noise-margin number.
I'm in a very rural area and only got one VHF channel for 30 years. Now I get over two dozen, many with HD TV.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
