Re: SCORE! Distillate Manifold!
Posted by Janicholson on November 07, 2009 at 10:22:24 from (64.61.211.26):
In Reply to: Re: SCORE! Distillate Manifold! posted by Mike CA on November 07, 2009 at 10:02:13:
Substantially more Probably 900 to 1000 at the stack joint in question. It is also hot enough to turn aluminum into aluminum oxide (not as in melt, but as in deteriorate). H's ruin the aluminization off of their mufflers in one session with work. JimN
