Posted by rustyfarmall on November 07, 2009 at 14:17:24 from (209.152.78.140):
In Reply to: Soda Blaster posted by DONALD SCHNUPPER on November 07, 2009 at 14:09:07:
Soda blasting is the same as sand blasting, except for the media being used. Soda is mostly recommended for more delicate parts, and a Cub really isn't all that delicate. Soda is also much less aggressive than glass beads or silica sand, and may not be very effective at all when trying to remove several layers of paint or built up rust.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
