The M distributor drive turns counter clockwise, opposite to the M, so you can't use a distributor or mag from an M. If it was me, I'd get the mag rebuilt and use it. If you change to battery ignition, the switch that works with the gas/diesel change over lever will not work. It's set up to ground the mag and shut off the spark when in diesel position. If you have the mag rebuilt, it will likely cost no more than changing over to battery ignition and you'll likely never have to do anything to it again.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
