Farmall Tractors Discussion Board
Re: Farmall H: 4th gear slips out
Posted by justin on December 29, 1998 at 16:12:13:
In Reply to: Farmall H: 4th gear slips out posted by Adri van Dijk on December 29, 1998 at 13:07:01:
I just fixed the same problem in one of my Hs. I originally rebuilt the frontbearing cage , but the problem was still evident. Next I replaced the shift forks, and still the gear would pop out. I finally just removed the whole transmission, and noticed the real problem, the drive pinion and the fourth and fifth slider were shot.. I really needed to replace everything that I mentioned above, but the replacement of the shift forks and the trans gear and drive pinion, was ultimately caused by the front bearing cage being worn out.. just examine everything, and replace what is ultimately needed.. good luck..
Post a Followup
: Re: Re: Farmall H: 4th gear slips out
