Posted by paul case on November 07, 2009 at 15:29:12 from (173.113.171.81):
In Reply to: Re: Factory wide fronts posted by rustyfarmall on November 07, 2009 at 14:24:00:
all later factory wide fronts have cast spindles and most aftermarkets have spindles welded to a stub axle. these will break under moderate to heavy use with a front end loader on ne ok's rocky ,rough field conditions got the t-shirt pc
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
