Re: 560 Shifting
Posted by Gary Hutchinson on November 07, 2009 at 18:44:30 from (96.60.58.132):
In Reply to: 560 Shifting posted by Texas Denny on November 07, 2009 at 14:42:40:
I was having that problem with mine so I adjusted
the clutch and TA. I followed the IH manual, but
I'm no tractor mechanic. It didn't make any difference with the problem. I also had little
clutch play. The clutch would either be out or in, not much in between (makes it hard to ease
a load without a lot of hopping). Long story short, I now have a new clutch and no more problem.
