Re: Starter drives
Posted by pete 23 on November 08, 2009 at 10:45:46 from (173.87.147.73):
In Reply to: Starter drives posted by Robert Lorencz on November 08, 2009 at 06:56:04:
No particular method, vise or channel lock pliars to pry washer ahead just enough to get screw out part way so it clears shaft. They are a little difficult but they will come around. As you can see, it has no overrunning clutch and is engaged by irertia so not actually clutch drive. Also, use only the small washer on drive end so as to control end play of armature.
