> Never ran into this and wondering what effect, > if any, his cranking away with it hooked up > backwards might have.
None. The starter is a series motor. It doesn"t care about the battery polarity. The generator must be properly polarized for the battery polarity, though, and the ammeter connected properly or it will register backwards. As 6 volt systems are almost always positive ground I suggest that you rewire it that way and then repolarize the generator. I"d also inspect all of the wiring (not that there is much) to see what other improvements he may have made.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
