As you said the mag uses a grounding switch--it should have only one terminal. The battery voltage has nothing to do with the mag, it is not supposed to be connected to the mag. Sounds like you need a new switch. You simply run a wire from the stud/nut on the mag to the switch. If the mag was rebuilt, any internal problem with that connection should have been fixed.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
