Re: Six volt system hooked up backwards
Posted by CNKS on November 08, 2009 at 14:14:57 from (216.144.104.128):
In Reply to: Re: Six volt system hooked up backwards posted by ScottyHOMEy on November 08, 2009 at 13:55:08:
My little used C has been reversed for 3-4 years. Due to difficulty getting the battery out (my cables are custom fit), I haven't fixed it yet. Wrong wire to coil also -- still gives a good charge (to the left, of course). Will cost me $70 for a NAPA regulator some day.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
