Re: Help with MD 12 volt set-up
Posted by D Slater on November 08, 2009 at 16:29:02 from (71.164.46.231):
In Reply to: Help with MD 12 volt set-up posted by Fallon on November 08, 2009 at 10:58:36:
IH owners manuals for your model tractor said to switch to gasoline then shut gas off and let engine run out and die. Mag was only grounded from a short wire going to manifold switch. Some MD tractors had switches added like the gasoline tractors equiped with mags to ground mag. Some operators just shut them down on diesel. Lots of different opinions from operators on the best way to shut them down on gas or the diesel side.
