the only difference hooking the coil up with polarity backwards is the spark pattern will be backwards.to prove what i'm saying hold coil wire approx. a 1/4 inch from a good ground spin engine observe spark pattern, should be arrow shaped, change polarity the arrow shape will face the other direction,on dc current it flows positive to negative, engine will run either way with out hurting coil,seen a many a one running this way,i've always tried to hook them up correct when working on them, never understood the reason for positive grd. except on trucks it was claimed to stop electrolysis that would eat holes in clyinder walls from water jacket side, don't know if that all the problem.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
