1948 Farnall Cub front fan pulley problem
Posted by Mark JMF in Mich. on November 09, 2009 at 08:54:00 from (76.221.246.146):
My 1948 Farmall Cub front wheel pully is binding up. This is the pulley that is the adjustment for the belt that has the fan blades attached to it. I took it apart and don't understand its assembly and function. If you look under the fan blades there is a plate that covers several holes and a nut that holds a separate piece of steel. How do I know if this is good or bad? Are there supposed to be bearings in this assembly? Any help would be appreciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
