Posted by Dan Bear Kelley on November 09, 2009 at 10:01:19 from (140.32.120.188):
Hi Y"all,
My Father-in-Law visited this last weekend. My M is now running so sweet... It has never run this well!!! We did not have to crack open the carb. So, my carb rebuild was good. He just did a few tweaks. More importantly, he showed me what he did and explained why. The cooling system was nice and tight, so that side plate was sealed well enough. For those following my M"s saga, I"ve got a BIG grin now.
Some time ago, I was able to get an IH WFE for my M. In the IT shop manual, it shows some kind of adapter plate between the WFE bolster and the tractor bolster. I do not have this plate. Should I be worried? or will things bolt up without it? Will it be a real pain to get someone to fab a plate for me? Would Steel Wheel Ranch have these?
Also, in the throttle linkage, there is a bell crank between the throttle handle and the governor control, right at the cylinder head. At that point is a dual-spring arrangement. I"ve got a ton of slop there. We tried replacing the springs, but couldn"t match the springs well at all. We went a bit on the stiff side, because we could not find springs that were close. Anyone have a good source for springs that would be close to factory? The little T-shaped pin that slides on the throttle rod is wollowed out pretty good, too. Just weld it up (or braize it up) and redrill? I figure I should also clean and polish the throttle shaft there.
THANK YOU for being a continuing source of information.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
