Posted by Bob M on November 09, 2009 at 11:29:41 from (151.190.254.108):
In Reply to: Farmall Loosing Power posted by Kendog on November 09, 2009 at 11:00:19:
Ken - Run the tractor and SLOWLY close the choke when it starts to lose power. If you find a choke setting where the power returns - even if briefly - it's fuel flow problem.
However if choking makes no difference be looking at the ignition - coil or condenser going away as it warms up, breaker point gap set too close, etc.
Could also be a temperature-related vacuum leak (manifold gasket, etc). However if this is the case the engine will generally run poorly at speed and stall the moment you close the throttle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
