Re: 300 Water Temp.
Posted by Bob M on November 09, 2009 at 12:42:59 from (151.190.254.108):
In Reply to: 300 Water Temp. posted by bkpigs on November 09, 2009 at 11:45:20:
If everything is right the temp gage should come at least to the bottom end of the RUN range just putting around with no load.
But the "low temp" problem could also be the temp gage reading lower than actual water temp. (Not unusual to happen as the gage wears out).
You can test by removing the sending bulb from the head and immersing it in a pan of boiling water. If the gage is working the hand should stop near the very top of the RUN band.
