Re: 656 Farmall
Posted by DANWV on November 09, 2009 at 13:30:36 from (207.255.204.112):
In Reply to: Re: 656 Farmall posted by Pat-CT on November 09, 2009 at 12:57:43:
Pat-CT
Which is the proper way to apply the TA.
Easy or quickly.
Will the incorrect method ruin the TA?
The tractor is still useable with a bad or slipping TA?
I am not farmiliar with them.
Anti-freeze and oil look to be fine. Is leaking oil from the tappet cover on the left side of the engine. I had a D282 on a front end loader and I know they can be a bear to start in the cold.
There is a block heater plug hanging from the engine.
