Re: Farmall C pto spec
Posted by Stan(VA). on November 10, 2009 at 05:22:08 from (70.4.49.125):
In Reply to: Re: Farmall C pto spec posted by dhuth2 on November 09, 2009 at 22:56:46:
I didn"t find torque specs either, that"s why I showed the HP formula and calculated it from hp and rated rpm. The Nebraska Tractor Tests Since 1920 book by CH Wendel shows the their 1948 (test#395) results of ~19.91 belt HP and the rated RPM for the C of 1650. This is somewhat of a fudge since it"s not clear what RPM the max belt HP was taken at? But I used "rated RPM" so should be good enough for a general point of reference. Hope that helps,
Stan(VA).
